Lifter Tapping
Old Sep 16, 2010 | 12:31 PM
rob69zombie's Avatar
Default Lifter Tapping
Last winter I noticed that I had a lifter tapping. It's been 9 months or so and it hasn't improved or gotten worse. My question is this; should I be OK to do a cam swap? I don't have the $ to do the heads (with lifters) right now and wanted to know some opinions. My motor has 93, XXX miles on it and is otherwise great. Thanks.
Old Sep 16, 2010 | 01:48 PM
IWGF's Avatar
I would not swap a cam if you've got a tapping lifter. Save your money and just do your whole top end at once.
Old Sep 16, 2010 | 02:16 PM
HotSilverBird's Avatar
Easy fix, buy 1 Qt of Rislone and put it in the oil.....lifter tap gone BIG SMILE on yer face.
Old Sep 16, 2010 | 02:23 PM
ChefTA's Avatar
I also have had a stuck lifter or (ticking) for over a year. It drives ok, but there is a noticeable loss in power, oil pressure is fine, but when WOT it flat out hauls @ss. Where can I get this Rislone? I might want to try it for now;as I'm currently saving green to build a 418.
Much appreciated
RJT
Old Sep 16, 2010 | 02:38 PM
Brent87LT1's Avatar
I had a lifter ticking, car ran great! Oil pressure was good. Turned out to be this:
If you're planning to do a cam swap, Just save up another $140, call up Texas-Speed, and order some of these:
Old Sep 16, 2010 | 03:15 PM
Thanks guys. I may just pull the heads and replace the lifters and trays with the cam swap. It'll be easier to do the valve springs anyway.
Old Sep 16, 2010 | 03:22 PM
ChefTA's Avatar
Ouch! That sucks. Well, I picked some up and will give it a try. If there's no cure, then it's most likely internal damage. I don't drive the car everyday, but with the lifter ticking it's sorta taken away the "edge" of cruising around town in my muscle car
Pictures are great btw.
Thanks
Old Sep 16, 2010 | 04:25 PM
Brent87LT1's Avatar
Not trying to be a jerk, but you have to pull the heads to do a cam swap anyway.
Old Sep 16, 2010 | 04:30 PM
IWGF's Avatar
WAT? No. You don't.
Old Sep 16, 2010 | 04:31 PM
SOMbitch's Avatar
Ummmmmmm......Not on a LS1
Edit: Haha IWGF beat me by 1 minute!
Old Sep 16, 2010 | 04:36 PM
IWGF's Avatar
Old Sep 16, 2010 | 06:14 PM
Johnny-LT1-runner's Avatar
Rockstar
Not here in SBC land. What have you been working on? Fords?
Old Sep 16, 2010 | 06:40 PM
That must have been one hell of a tick!
Old Sep 16, 2010 | 09:33 PM
If I had to pull the heads off anyways, it wouldn't be an issue. I think that's my route anyways.
Old Sep 17, 2010 | 08:43 AM
Brent87LT1's Avatar
OK, you guys have me curious. I just cammed my LS6 and can't imagine being able to pull it without removing the lifters. I've built tuned ports & LT1s in the past and obviously you can raise the lifters from under the intake. Not really an option on these engines though...
School me please.
Old Sep 17, 2010 | 09:15 AM
CRAZZ28's Avatar
School me please.
On the LS1 rotate the cam quickly back and forth and the lifters will push up and "lock" into the lifter trays. although its a good idea to use something to make sure they stay in the trays.
Old Sep 17, 2010 | 10:05 AM
Brent87LT1's Avatar
I see. So you're just hoping they stay up & worst case scenario, you have to pull the heads anyway.
Old Sep 17, 2010 | 06:39 PM
Use dowel pins to hold them up.
Old Sep 17, 2010 | 07:15 PM
IWGF's Avatar
This is the right answer.
