Need advise on building a 383 ls1
Old Sep 16, 2010 | 08:59 PM
01turboformula's Avatar
Default Need advise on building a 383 ls1
I have a rebuilt stock ls1 short block that I wanted to throw into my formula since I blew the last one due to water getting sucked in through my turbo, I was originally planning on dropping the stock block in but I've decided to build a 383 since the rebuild is out of the car. I've already priced a rotating assembly from eagle for the build and plan on running a s/c-turbo cam from edelbrock. I'm also needing to know how much to bore the cylinders for the build, what heads,intake,tb,valvetrain etc..to run with the build. I will still be running my sts kit with this build so any advise and help I can get will be greatly appreciated.
Old Sep 16, 2010 | 10:12 PM
garygnu's Avatar
you can hone the ls1 block out to 3.908.get a cam from the same place you got the turbo kit.or consider a custom cam from Patrick-G. look at some trick flow 220cc cast heads,good flow good price.you can find a used BBK and TB in the used parts section for $550 or less..get custom push rods ,use a adjustable push rod checker to determine the proper length.get some compcam trunnion bearing for you stock rockers.
