crane 1.8 rockers advice
Old Sep 17, 2010 | 01:35 AM
Ss98sS's Avatar
Default crane 1.8 rockers advice
i am putting a ms3 cam and gona try and find a decent set of 243s or go with a prc head idk yet but i came across this guy with crane gold 1.8 rockers. i was planing on keeping those stock. would these give me some good hp or would it be a waste? would these effect any thing else if i did buy this like my push rod length.....? Thanks
Old Sep 17, 2010 | 04:41 AM
vettenuts's Avatar
Crane rockers require a full kit of rockers, polylocks, guide plates, studs and pushrods. On a stock motor, they require 7.250" rockers. I would not use the 1.8 Crane rockers with the MS3 cam. For starters, the Crane rockers come off the seat very quickly and will reduce PTV over stock rockers. Crane rockers, either 1.7 or 1.8, would reduce the PTV value. You would also need much stiffer valve springs and larger OD pushrods to keep things under control for a minimal gain.
Bottom line, don't buy the rockers with your setup.
Old Sep 17, 2010 | 08:53 PM
Ss98sS's Avatar
well i was planing on putting some good springs on and good pushrods in. so you think bottom line its not worth putting on with my set up. my goal was to build the whole top end so.
Old Sep 18, 2010 | 01:33 AM
GT_EATR's Avatar
I currently have the MS3 cam package for TSP...I got the PRC double valve springs and hardened pushrods but theyre standard 7.400 Length...I know the MS3 is a big lift cam already..would a new set of rocker arms really help...i know it would increase lift but what would the proper selection be??? i have no prob buying the complete kit...i jus want it done right...So im in the same boat as Ss98sS
Old Sep 18, 2010 | 09:12 AM
vettenuts's Avatar
You're throwing away money. The Cranes are very fast off the seat so you are also asking for valve train issues. More is not always better.
Old Sep 20, 2010 | 01:21 PM
Ss98sS's Avatar
alrighty sounds good to me should what do you recommend to buy cuz i would only like to build the top end once. thanks for all your help..
Old Sep 20, 2010 | 01:46 PM
Nastyc4's Avatar
Not trying to jump in and sell you anything but I have a full kit of crane 1.85s with locks retainers and proper pushrods i 'may' be selling. My local shoppe is telling me to just do a cam swap so i'm kind of torn right now which way I should go..
Old Sep 21, 2010 | 11:25 AM
Ss98sS's Avatar
lol no thanks i was gona pick up some because i think i could have gotten the whole kit for 100 bucks but if i dont need them i dont need them...
any sugst. on what i should put on there for a good set.
Thanks a lot
