will this setup work having some second thoughts
Old Sep 17, 2010 | 09:49 PM
little_chewy_69's Avatar
Default will this setup work having some second thoughts
okay just finally got all my parts in and i don't know if this setup will work i think i might have some ptv clearance issues
tsp balanced 383 rotating assembly with wiseco 8CC dish pistons
MS4 cam
PRC stage 2.5 5.3L heads
i talked to TSP and this is what they gave me for a setup the MS4 is a big cam and the PRC's have a small combustion chamber....do you think it will work or has someone ran this setup??
Old Sep 18, 2010 | 05:58 PM
SSPerformance's Avatar
youu should be fine mesure your PTV clearance when doing the motor.... i ran 5.3 heads on my 408 with a 244/248 630 lift cam....
Old Sep 18, 2010 | 08:14 PM
this will be weekend car but would like good street manners maybe i don't know a lot but i thought it was a little big for DD but they said it wouldn't be a problem if i had a competant tuner
Old Sep 18, 2010 | 11:21 PM
1SLwLS1's Avatar
Driveability is all in the hand's of the tuner. Measure, but it should be OK as most small dish pistons still have valve reliefs cut into them. My 4.030 Wiseco -8cc dish pistons do.
