Push rod lenght to use
Old Sep 20, 2010 | 03:55 PM
CGriff04's Avatar
Default Push rod lenght to use
Hey guys running a set of TF 220's that have been milled to 59cc LS2 heads on LS1 motor. Im running 7.400 push rods at the moment. I think they may be too long and holding the valve open. What ones should i be running with this set up?
Old Sep 20, 2010 | 04:47 PM
01'SSLSX's Avatar
im a cam only ls1 with stock 241 heads, and my tuner told me to use 7.350 push-rods.
he has built several lsx engines, so i figured he would know what was best
Old Sep 20, 2010 | 05:20 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
There are too many variables in this one to guess at it. I would HIGHLY recommend the $20 pushrod length tool so you can eliminate the guess work. Next time one of your buddies needs to use the tool, do it for him and charge him $20 for telling him the correct length and your tool is paid for!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Sep 20, 2010 | 06:24 PM
SOMbitch's Avatar
I am using 7.5 with those heads at 60.5cc so you should be close..... But yeah you need to measure...
