Torquer V3 with 62cc heads?
Old Sep 23, 2010 | 10:12 AM
Rise of the Phoenix's Avatar
Default Torquer V3 with 62cc heads?
Will that cam fit without having to flycut. I believe the specs are 231/234 111 LSA. Anyone running that cam with heads millled to 62cc?
Old Sep 23, 2010 | 10:56 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
What kind of heads are they? Do they have larger valves? How much were they milled to get to the 62cc chamber? We will need some more info before we can properly answer that question.
Old Sep 23, 2010 | 12:28 PM
They are AFR 205 heads. I don't believe they have the larger valves and I think they started out a 66cc and were milled down to 62cc. I appriciate your help.
Old Sep 23, 2010 | 02:21 PM
That setup should be able to clear with no issues but I would definately measure before you actually fire the motor over. AFRs start with a thicker casting which allows these kind of build to work without flycutting.
Old Sep 23, 2010 | 03:31 PM
Thanks a lot John, I appriciate your help. Have you seen anyone use this setup before?
Old Sep 23, 2010 | 03:36 PM
I can't say that I have seen that exact set up with the AFRs but I know we have done a couple sets of our PRC 215s with the torquer v.3. The last one that sticks out in my head was a M6 Trans Am that put out 441 rwhp and 408rwtq with an LS6 intake. With a FAST I think 450+ would have been attainable.
Old Sep 23, 2010 | 03:42 PM
Nice, my goal is anywhere from 440rwhp to 450rwhp. I plan on doing a FAST later down the line, but for now, the LS6 intake will have to do.
Old Sep 23, 2010 | 06:25 PM
260B4U's Avatar
hey Jon
whats the recommended ptv clearance on a manual car
70 thou 100 thou most people are saying 100 thou to be safe in-case of over rev but everyone's got a different # in their mind that's safe...
also do you know how much the LS6 pistons are out of the hole?
i'm trying to run 60cc afr's on the tsp v3 111 LSA and every one is saying its not gonna happen with out fly-cutting also does tsp loan/rent out a fly-cutting tool set
any opinions or advice
Old Sep 23, 2010 | 11:59 PM
SOMbitch's Avatar
Originally Posted by 260B4U
hey Jon
Generally accepted streetcar minimun is .080 intake and .100 exhaust because the piston and valve are moving towards each other..
Average about .007 out of the hole.... Yea my guess is flycut but ya never know.. chrs1313 on here will rent you a Lindy tool....
Have fun
Old Sep 24, 2010 | 08:43 PM
260B4U's Avatar
this might be a dumb question but why is hitting the rev limiter/over rev bad its a computer generated rev limit not mechanical rev limit so why would the set clearances change or be in jeopardy
