Valve Spring Question
Old Sep 27, 2010 | 04:37 PM
Infantrymarine's Avatar
Default Valve Spring Question
I bought a TSP Torquer v2 from a member on here and a set of dual valve springs good to .675 lift. Obviously stock retainers won't work on "fat" springs like that. My question is, would I be better off buying some aftermarket retainers to fit them, or should I go with something like the "918's" from Comp? Lift on this cam is .595/.598. 918's are good to .600. Another option I was thinking was the PAC's from Texas Speed. The 1218's are good to .600 and the 1518's are good to .650 but are $100 more. Help me decide gents.
Old Sep 27, 2010 | 04:40 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
If they are the PRC .675" lift springs, you've got a great spring and just need the seats, seals, and retainers! Those items will run you about $200 or so.
Or you can go back with a PAC 1218 or equivalent....they'll cost you about $170 plus the cost of new seals and retainers if you want to replace those.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Sep 27, 2010 | 05:10 PM
Is it a MUST that the seals and retainers need to be replaced if I went with the 1218's or can I get by with stock? They are the PRC's, I'm just looking for ease of installation and ease on my wallet right now.
Old Sep 27, 2010 | 05:31 PM
No, for the beehives you do not have to replace the seats/seals if they are not leaking currently!
__________________
Old Sep 27, 2010 | 05:49 PM
Ok, thanks for your help Matt!
Old Sep 28, 2010 | 09:13 AM
Anytime! Let us know if we can help!
__________________
