99 Z28 Rebuild
I replaced the Cam Position Sensor and it still will not fire. The Fuel Pump is working. I guess the next thing to do is check the wiring. Any other ideas?
Thanks,
Brian
I replaced the Water Pump at the same time since I had it off.
I wonder if the timing chain could have went.
To check for timing chain problems you can.....
Get a scope and look for a wave form to assure the timing chain is not broken.
Compression check to see if the chain is broken.
Pull the cover.
btw the tach needle moves just not much.
