Need engine advice
Old Oct 4, 2010 | 04:52 PM
psi2high's Avatar
Default Need engine advice
Ok so for what ever reason my ls1 decided it wanted a new window and apparently the pistons tried to escape out this window. Now I think it seems as though its cheaper to go the lq4 short block route. Does any one know(assuming the heads are still good) if cartek stage 3 ported heads would work with this set up? Also what else would I need to do in order to run this set up? Thanks alot and sorry for the newbish question.
Old Oct 4, 2010 | 06:15 PM
RedHotG8's Avatar
To know for sure sure call them at 908.317.4496
Old Oct 4, 2010 | 07:35 PM
psi2high's Avatar
Yea Im going to give them a call tomorrow morning. Trying to figure out the best plan of attack with out breaking the bank
Old Oct 4, 2010 | 08:43 PM
psi2high's Avatar
What would be the best 6.0 block to go with? The lq4 or lq9?
Old Oct 5, 2010 | 05:59 PM
psi2high's Avatar
Will all the accessories bolt right up?
Old Oct 5, 2010 | 10:59 PM
Always2Slow's Avatar
yep you just have to tap one hole in the block for the alternator bracket, but it will all bolt up.
Old Oct 6, 2010 | 11:12 AM
psi2high's Avatar
There is probably a thread that shows what needs to be tapped correct?
Old Oct 9, 2010 | 01:06 PM
psi2high's Avatar
Think I am going to build it for boost. A 6.0 would be the best block for a f.i car correct?
Old Oct 10, 2010 | 11:37 AM
SOMbitch's Avatar
A lot of guys just use two bolts and get by fine. IIRC there is a boss on the block where it goes though.
For boost an LQ4 would be best because the pistons are dished to drop compression... If you are going to build it get whatever is cheapest because the blocks are the same... but LQ4's are usually cheaper..
Old Oct 13, 2010 | 04:38 PM
psi2high's Avatar
Thanks Im gonna look around now for some blocks
Old Oct 13, 2010 | 08:22 PM
garygnu's Avatar
Schwanke engines is selling 5.7 short blocks for $1500 in the group buy section.
Old Nov 2, 2010 | 10:36 AM
psi2high's Avatar
Think we may do the lq4 and throw some boost at it
