Cam Swap
Old Jan 29, 2004 | 05:41 PM
BYOFICR's Avatar
Default Cam Swap
Is air tools a must for swapping just the cam? I had them when we put it in as well as the valve springs (but those are staying in). TIA
Old Jan 29, 2004 | 07:16 PM
jrp's Avatar
jrp
SN95 Director
no. i've yet to use my air tools on my head and 2 cams swaps. used the TDC method changing the springs and my 2 breaker bars and regular sears tools for everything else needed.
Old Jan 29, 2004 | 07:32 PM
more carbon's Avatar
what is the trick to gettin' that balancer bolt out,that sob is tight
Old Jan 29, 2004 | 07:47 PM
Ferocity02's Avatar
No air tools are not... in fact they should not be used, they can break off bolts, round them, or over torque them. Don't even use an impact wrench on the crank bolt. I used a breaker bar, let it hang down towards the ground, and then I layed down on the and use my legs to push the bar while bracing myself on the tire. It will remove the bolt like its nothing...
edited for spelling....
Old Jan 29, 2004 | 08:10 PM
jmX's Avatar
jmX
I've never used any airtools for my camswaps, other than when I used one once to fill the cylinders with air to hold the valves up.
Old Jan 29, 2004 | 08:20 PM
jrp's Avatar
jrp
SN95 Director
breaker bar
i got a 24" and a 15" set; best damn 2 tools i ever bought.
Old Jan 29, 2004 | 08:26 PM
Steve01SS's Avatar
Originally Posted by jrp
breaker bar
Agree.. same here... and if that doesn't work I have a 36" piece of galvanized pipe I slip over one of the breaker bars as a cheater bar. Bolts WILL come out.
Old Jan 30, 2004 | 01:43 AM
frankensteinta's Avatar
Air tools are nice, but you don't really NEED them for much of anything.
