Pulled my head and saw this..
oh and there was some sort of red fluid laying on the piston. at first i thought it was transmission fluid but i cant really smell this fluid at all.
any recommendation ? should i put a piece of wood there and bang it loose? from the bottom or from the top?
Doesn't really matter what it is at this point, if you are going to use it that motor needs to be rebuilt.
Aslo the red stuff could be MMT (Methycyclopentadienyl Maganese Tricarbonyl). MMT is an anti-knock additive in gasoline used to replace lead. During the combustion process, the MMT leaves a reddish deposit... Sometimes it shows up if octane boosters or gas additives.... It may be in th gas.... and combined with the carbon o the piston or chamber....
question. while im down there. if i get lucky to just do a hone job and i need to replace the piston and ring. what would u guy recommend? flat top or some dish piston to bump up the compression? im probably keeping this motor N/A daily but 150 shot occasionally.
