oil change turned bad?
last time i listen to guy at a parts store before before doing my own research.
did the change, drove about 30 miles or so
took it to the track at night and it drove like *** and feels like a great loss of power, especialy after 4k RPM
i hope its just too much oil, im going to drain it today and find out if its better. THIS time im only adding 6 quarts.
car is a rx7 with a 99 vette ls1 with auto trans, BONE stock.
would too much oil cause this bad performance? car keept running 15's in the 1/4 mile!!!!
only did 2 runs spinning alittle before i noticed somethign isnt right motor wise.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
You may also have other tuning issues if your car is running like a turd.
what exactly are some of the oens i should be looking for?
im going to drain some of the oil and if its still acting up, ill move on to the next step, whatever that might be
"7 qts probably would have ended up giving you a ton of blowby and fouling the plugs. The PCV system on the early LS1's is a known weak point and will end up causing you to burn lots of oil even when you don't over fill the system.
Change your oil again. Put the right amount in, Swap over to the LS6 valley cover and a good catch can, then put some new plugs in it. I'm willing to bet it'll run much better."
but another guy said it could be a trans problem.
when i floor the car it spins alittle thru first, hits second spins alittle, and in 3rd it usualy cherps.
car dosnt have LSD but i imagined that a bone stock ls1 should have no problem burning thru 1st gear and most of 2nd.
keep in mind that its an a 2nd gen mazda rx7.
Reaction---- .6636
60 FT------- 2.2519
330ftFT----- 6.5633
1/8 ET------ 10.1506
1/8 MPH---- 69.16
1000 ET---- 13.1686
1000 MPH--- NONE
1/4 ET------ 15.7167
1/4 MPH----- 89.18
yeah, im having a guy i know (adam) he might go as warhawk on here, not sure. but he has been giving me some advice and if he cant figure it out i might try someone off this forum or try giving james from running with the devil a call, or someone of that nature.
Check the condition of the engine oil on your dispstick, if there is no sign of frothing, then 7 qts is fine. Why would you change the oil again (makes no sense)...?
Extra oil does not increase blowby (does he know what blowby is...?), and it doesn't cause the PCV to suck any more or less oil.
Even without a catchcan and LS6 valley cover, you should get better performance that what you said.
When you're holding 3rd gear (lever in manual 3rd position) and the TCC locks, increase throttle but avoid a downshift, if RPM stays constrained/loaded then the trans is not slipping, if RPM quickly moves up then trans is slipping. How much fluid do you have in the trans (you can overfill it by 1/2 qt as long as no frothing)...?
Even with worn plugs you should still get reasonably good performance.
You have some other problem... your handheld may not be sufficient for viewing all the waveforms together.
$0.02.
