LS1 build
Old Oct 14, 2010 | 02:48 PM
nando105's Avatar
Thumbs up LS1 build
hay guy's i'm trying to build a 500 to 600 hp ls1 for my drift car. i currently have the stock motor in my 95 nissan 240sx. i came up with a list and here is what i was thinking of using
parts.
eagles 383ci stroker kit
world warhawk 235cc heads
cam ? was thinking comp cams XFI cam but world heads spec to use solid roller cam.
fast intake with 90mm + get port.
fuel injectors?
for the cam if anyone can point me to a nice lob cam for high revving thanks and as for fuel injectors ? what would be a good pair, if anyone has info hit me back thanks
Old Oct 14, 2010 | 03:07 PM
brians91formula's Avatar
first off, are you looking for 500- 600 rwhp or crank hp ?
second, dont buy anything from Warhawk. I have heard nightmares about their crappy machine work.
Old Oct 14, 2010 | 08:50 PM
SSPerformance's Avatar
Dont waste your money on thoes heads>>>> id go with some trick flows
Old Oct 14, 2010 | 10:11 PM
SOMbitch's Avatar
If you decide to run those heads talk to World and see what they recommend. I would personally go with another head but I don't know your intended use of the car is...??
Old Oct 14, 2010 | 11:20 PM
Stealth Camaro's Avatar
From a previous experiance .. the following setup put down 530rwhp via A4 car
- Trick Flow 215cc Heads
- Custom Stroker Cam by Speedinc
- 383cid End Bottom ( Diamond Pistons 3.905" flat-top -2 / Callies Rods 6.125" / Callies Crankshaft )
- Total Engine Airflow Ported Victor Jr
- 4 barrel TB with scoop ..
Old Oct 16, 2010 | 04:00 PM
nando105's Avatar
i'm looking to stay fuel injected and i'm looking for rwhp.
Old Oct 16, 2010 | 05:55 PM
ls1curt's Avatar
you wont make 600 whp with a 383 n/a. a set of tfs or afr's and a custom cam along with the fast 90/90 will put you solidly in the 500's tho
Old Oct 16, 2010 | 06:01 PM
garygnu's Avatar
get a fast 102mm intake and TB.use a fuel injector calculator for the injector size,contact FIC.prc 227,or afr 225/235,or tfs 235.get a cam from Patrick-G.search for a 383 build by Tony Mamo of afr.
