need a little help with shortblock build
Old Oct 14, 2010 | 06:15 PM
slowlsx's Avatar
Default need a little help with shortblock build
i have a 5.3 iron block that i bored to 3.905 and i have diamond pistons and 6.125 eagle h beam rods. is it possible to put a 4.00 crank to make it a 383 with this iron 5.3 block?
Old Oct 14, 2010 | 07:16 PM
SOMbitch's Avatar
Sure. Just clearance the block. You might also have to mod the windage tray...
Old Oct 15, 2010 | 08:17 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
Yes, not a problem. We do them as kits and they work great.
Old Oct 15, 2010 | 03:00 PM
Jon@Texas-Speed's Avatar
Make sure the pistons are built for the 4" stoke crank. It will change the pin height of the piston. If the pistons are built for a stock crank, you can't put a 4" crank it it. They will come too far out of the hole.
Jon
