engine building pressure in valve covers...need help!
Old Oct 21, 2010 | 02:25 PM
98modified's Avatar
Default engine building pressure in valve covers...need help!
Ok a little back ground info...It is a rebuilt LS1 with just over a 1k miles. Has heads, cam, lifters, pushrods, rockers, lS6 valley cover, LS6 intake manifold, and long tubes. Has a tune for all but the stock rebuilt short block, 1.75 rockers, and long tubes. Started out with a poor idle and then i noticed the sound of pressure letting off after i kill the engine. Mech says thats from the valve covers. if you remove the oil cap it shoots it off. If you give the engine a vaccume leak it idles better, guessing the cam needs more air at idle. My main worry is the pressure building up in the covers.
Any thoughts?
Old Oct 21, 2010 | 08:44 PM
S10xGN's Avatar
Rings, head gasket(s), PCV... Leakdown test will narrow it down.
Old Oct 21, 2010 | 08:49 PM
SSPerformance's Avatar
you are building up crank case presure.... make shure you PCV system is hooked up correctly or you will blow the rear main or front seals...
Old Oct 22, 2010 | 01:01 AM
01ssreda4's Avatar
My thoughts also.......
