Cam position sensor question
Old Oct 23, 2010 | 07:46 PM
fueltruck's Avatar
Default Cam position sensor question
Hello all,
Just put my 2001 T/A together with an MS4, new lifters, pushrods and springs in it. Started up just great but I noticed my tachometer is not working. I'm pritty sure I know where the sensor is.. but just to make sure, its right behind the intake manifold comming vertically out of the top of the block right? Mine only had 1 white wire in it to begin with and seemed.. flimsy at best. This it? thanks
Ian
Old Oct 23, 2010 | 08:59 PM
Arc00TA's Avatar
I don't believe the car will start without that plugged in (mine didn't), but its worth a try. If you reach from the passenger side you should be able to feel the plug, right under the block on the back of the intake manifold for the MAP and vacuum lines.
Old Oct 23, 2010 | 10:32 PM
fueltruck's Avatar
huh... its a vertical tube with the plug on top right?
Old Oct 23, 2010 | 10:55 PM
99huggerorangeZ's Avatar
that is the OPSU not the cam sensor.
Old Oct 23, 2010 | 11:33 PM
Arc00TA's Avatar
Yeah thats the oil pressure sending unit. Probably not the reason you tach didn't work.
Old Oct 24, 2010 | 05:41 AM
bene's Avatar
Trunion King
Cam position sensor is right next to OPSU. W/O the CPS plugged in the tach will not work. My CPS came undone when I was putting everything back together and started the car and the tach was not working. It was harder to start also.
Old Oct 24, 2010 | 05:44 AM
bene's Avatar
Trunion King
Here is the image...
