Couple of questions before I start wasting money
Old Oct 25, 2010 | 08:03 PM
01cherryreds10's Avatar
Default Couple of questions before I start wasting money
Would like to use the set of LS6 243's I have on my LQ4.
1. Will I have any PTVC issues with a stock head gasket and a TR224 cam with stock pistons?
2. Should I use the LS2 head gasket with the 243's and 6.0 or is there a different MLS gasket I should use?
3. On the TR224 with a set of 3.73 gears, what would a suggested stall be? 2000-2400?
Appreciate any help
Old Oct 25, 2010 | 08:09 PM
Arc00TA's Avatar
243's are small bore. Use LS1 gaskets. Stall should be 3200-3500 comfortably, and the 243's will work great with that cam. I used stock 243's and 224R, made 430rwhp through an M6. No PTV issues at all.
Old Oct 25, 2010 | 08:20 PM
blsnelling's Avatar
I've got a 220/224 .581/.581 cam and 243 heads milled .035. No PTV issues.
Old Oct 25, 2010 | 10:56 PM
Awesome guys thank you both a bunch. Head bolts should be stock 6.0 correct?
Old Oct 26, 2010 | 03:06 AM
Arc00TA's Avatar
Ah shoot I missed that part. Yes stock bolts will be fine, and you were right you need the 6.0 gasket. For some reason I was thinking LS1. You will make some good power with that setup, killer low end torque.
Old Oct 27, 2010 | 07:13 PM
Awesome that's all I need is the low torque. Highest speed limit around here is 50
Once again appreciate the replies
Old Oct 27, 2010 | 07:45 PM
garygnu's Avatar
tr224 112*lsa,or compcam 54-455-11.
