Can it be done?
Assuming you stroke it to 4 inches, i think that would end up being a 400ci engine, assuming the lq4 has a 4inch bore, which i believe it does.
Now, if you can get ahold of some l92 heads, im sure you would be well over 500 at the crank (you would need a l76 intake however).
There's nothing cheap about a heads/cam swap. In fact, it could get really expensive if you decide to cheap out on it the first time around.
