trick flow heads??
Old Oct 31, 2010 | 01:01 PM
  #41
Ws6kid.'s Avatar
Originally Posted by flintwrench69
Trickflow dual springs good for either .600 or .625 lift.
the paper it comes with (the heads) say 650...
Old Oct 31, 2010 | 01:04 PM
  #42
Ws6kid.'s Avatar
Originally Posted by BOBS99SS
The ms4 I love and trickflow heads plane out rock,my car is tuned pretty good and my idle is a lil chopy but no where near others I have heard,but a cam that big a tuner can cut down on the surging and bucking at low rpms but imo you kind of will have that a lil bit no matter how good your tune is,mine runs really well, only surges just a lil bit,and only bucks just a very very lil at around 25 mph,we are still working on the tune though,but I'm sure with those heads what ever cam you go with will fly,I would agree on having pat g spec one for you,what kind of intake set up are you going with?I wish I had the extra money for trick flows they are really sweet heads and look like gold lol,you get a good cam in there,pop on a fast setup and you got a great combo that should make really good numbers but more important perform great,you did not mess up going with those what so ever
Any chance of every hitting the 500 range with those heads and a cam?
  #43
Ws6kid.'s Avatar
Originally Posted by Chaospartners
So that means i can have up to .600lift? i was actually looking at the trick flow cam, but cant find much good info on them. heres the link to one
http://www.summitracing.com/parts/TFS-30602003/. i just thought there cam might run good with there heads..
She didnt say much, lol she just said its ur debt!! haha
Good thing im single
Old Oct 31, 2010 | 02:55 PM
  #44
mike c.'s Avatar
For $600.00 more you could of got a set from t.e.a and had them hand finished for better results. A good set of heads is worth a few extra bucks,it's where the power is.
GRYGNU-A 7.5 pushrod does not always work. I now have the packagefrom vengeance. t.f.s 235 hads,custom cam,fast 102mm,yella terras. A 7.5 push rod held the valves open and i had no compression. We needed a 7.45 after a push rod checker was used.
Old Oct 31, 2010 | 04:42 PM
  #45
ct06gto's Avatar
No yella terra rockers for me. I will be going with the .090 shims, 11/32 x 7.625 puhrods and comp trunion upgrade.
Old Oct 31, 2010 | 04:53 PM
  #46
Chris05ssTruck's Avatar
IMO...stay away for the Harlem Sharp's...they have been know to cause valve float with the more agressive cams. They are HEAVY on the tip.They work fine in some set-ups and some they don't.
Old Oct 31, 2010 | 05:30 PM
  #47
Ws6kid.'s Avatar
ive herd the same =/
Old Oct 31, 2010 | 08:05 PM
  #48
garygnu's Avatar
chris1313 made 495 rwhp with tf ,find his thread.
Old Nov 1, 2010 | 08:40 PM
  #49
Ws6kid.'s Avatar
Will do!
