need help in modding my ls1
Old Oct 29, 2010 | 12:40 AM
jerrito98ss's Avatar
Default need help in modding my ls1
hey i lust bought myself my first car and its a stock 98 camaro z28 A4 and i have about 2g's to put in performance what should i do to get the most bang for my buck?
SexyTransAm's Avatar
spray the nuts off that bitch!
Old Oct 29, 2010 | 12:48 AM
what kinda spray setup should i get n how many shots?
Old Oct 29, 2010 | 01:13 AM
GT_EATR's Avatar
Stock LS1 you can hold 150hp shot on a wet setup...On stock bottome end...Get a tune for it to double check the timing and the A/F ratio while on the bottle....you can get a basic wet kit (Nozzle setup) for around $600...If u have $2,000 then i would go ahead with a nice Cam package that comes with forged pushrods and double valve springs...Cam,Springs,Pushrods will run you around $900 depending on type so you can do a cam install and have the juice for $2,000.00...Best way for max hp in my opinion...
Old Oct 29, 2010 | 01:14 AM
GT_EATR's Avatar
Look up Texas Speed & Performance MS3 cam package...comes with springs and pushrods for a great price if ur on a budget...Wicked cam also...I know from my setup its worth the $$
Old Oct 29, 2010 | 01:20 AM
they will go 200 shot easy on a good tune. and id do stall and headers before a cam.and a ls6 or bigger intake. or hell do what i did and do cam/ valve train, stall, headers, all at once
Old Oct 29, 2010 | 07:23 AM
94 Camaro Z28's Avatar
Are you going to be taking this to the track? Or do you want to just brag about big numbers? If you are going to be going to the track, I'd suggest a nice stall and 3.73's for the rear end. Then get a cam and intake. I personally would hold off on the nitrous since that **** scares me and i'd fear that it would mess up something that would be out of my budget to replace
Old Oct 29, 2010 | 01:08 PM
ok thanks for the tips
Old Oct 30, 2010 | 10:15 AM
Fabian's Avatar
High stall is a must. Who gives a **** about dyno numbers when your shaving 5-8 tenths off your quarter mile?
Old Oct 30, 2010 | 10:26 AM
KevinR's Avatar
Lid, full exhaust, converter, tune
Old Oct 30, 2010 | 10:40 AM
krissoto's Avatar
Gonna need a converter if your going with a cam,and if you do that should put a tranny cooler in as well...You can go along way with simple bolt ons and some juice. Cams not gonna give you overall satisfaction if it can't breathe or get the gas out. I would go with a lid, k&n poss p&p tb, do and ls6 intake and put an exhaust system on it. If you still have some $$ left you could do some laughing gas......Good luck. Research and research some more..
