Oil Pan Rough Casting, Bead Blast Inside?
Old Oct 31, 2010 | 05:05 PM
NovaKid's Avatar
Default Oil Pan Rough Casting, Bead Blast Inside?
Hi everyone, I just swapped my oil pan from a stock CTS-V pan to an F-body pan. The inside of the CTS-V pan I took off was flawless and smooth. The F-body pan I ordered from a Chevy dealership had really rough casting marks and slag on the inside bottom of the oil pan. It's pretty rough on the inside surfaces. Should I get the inside of the pan bead-blasted or does this even matter for oil flow? Has anyone else seen this type of thing before?
Old Oct 31, 2010 | 07:23 PM
ShevrolayZ28's Avatar
Yup, mine is the same way. At first I thought it was loose debris, but no, it's left over from their casting process. I wouldn't worry about it.
Old Oct 31, 2010 | 07:33 PM
tittan1500's Avatar
Mine is the same way dont worry
Old Nov 1, 2010 | 12:13 AM
NovaKid's Avatar
Hey thanks guys, I appreciate your input.
Old Nov 1, 2010 | 01:27 AM
01ssreda4's Avatar
Considering the oil is just draining into the pan the rough casting won't have any negative effect. My brand new pan from GMPP sounds exactly as you described.
