Need Valve Event Timing Advice
Old Feb 2, 2004 | 09:18 AM
Constrictor 98TA's Avatar
Lightbulb Need Valve Event Timing Advice
Lets say I had a cam that had valve events of:
Intake Valve opens - IVO 4 BTDC
Intake Valve closes - IVC 44 ABDC
Exhaust Valve Opens - EVO 46 BBDC
Exhaust Valve Closes - EVC -2 ATDC
Overlap 2 degrees
Now, lets say I know I am running .020" milled heads and I know my intake valve P/V clearance is tight, however I have plenty of clearance on the exhaust side.
So, I switch to a cam with these valve events:
Intake Valve closes - IVC 48 ABDC
Exhaust Valve Opens - EVO 56 BBDC
Exhaust Valve Closes - EVC 0 ATDC
Overalap 4 degrees
The Intake valve closing and exhaust valve opening would have no bearing in P/V clearance, but I am staying at the exact same intake valve opening position, and the exhaust valve closes 2 degree later than the original cam.
In theory, I shouldnt have any problems with P/V clearance, regardless of what the actual specs of the cam are....correct?
Old Feb 2, 2004 | 09:56 AM
Mike22ca's Avatar
I can point u to the right person to talk to. His name is Shaun (93pony). He's on here & cafords.com a lot. He is "Mr. Valve Events" LOL
Old Feb 2, 2004 | 05:23 PM
Thanks for the advice. I PMed 93pony, but does anyone else have any thoughts?
Old Feb 2, 2004 | 07:58 PM
Richard@WCCH's Avatar
It should work fine as long as the lift/degree ratio stays the same as the old intake lobe. Essentially you've switched to a longer duration and moved the centers apart. Should make for some great midrange and topend power. Acceleration suffers slightly.
Good luck,
Richard
Old Feb 2, 2004 | 08:50 PM
Good luck,
Richard
Thank you Richard!
