228R install idle problems
Old Nov 8, 2010 | 09:14 PM
mamead's Avatar
Default 228R install idle problems
Hi guys,
So far I've found everything I needed on here from searching. Awesome site. However, I just finished up my first cam install and am having troubles getting the car to idle on its own. Here is before the install:
98 T/A
long tubes
AIR and EGR delete
magnaflow catback with ORY
LS6 intake manifold
25% Underdrive pulley
New corvette O2 sensors
New plugs
New wires
Frost Mail order tune
Installed:
comp 228R 114 cam
comp 7.400 hardened pushrods
New springs
LS2 timing chain
I can only get the car to run at 1500 rpm or higher. I tried drilling out the tb very slightly, only about .020 larger though. I plan on getting a tune so I did not want to mess with drilling too much. I also adjusted the tb position screw up but still cannot get the car to idle. Multiple backfires and dies when I do not hold the gas at 1500 rpm or more. Is it simply a tune issue? Thanks.
Old Nov 8, 2010 | 09:32 PM
Chevy Guy's Avatar
Yes, you need a tune. DO NOT drill your TB any more,
Old Nov 9, 2010 | 09:09 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Agreed, a good tune should do the trick! No more drilling!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 9, 2010 | 09:13 AM
thunderstruck507's Avatar
Backfiring to me also sounds like you have a set of coils not plugged in all the way or damaged the harness to them...possibly plug wires.
Look over it just to be sure.
Old Nov 10, 2010 | 08:13 AM
flintwrench69's Avatar
I installed this same cam last year, without a tune I had to open the throttle some when cold so it would stay running but after it warmed up it wouldnt stall. I drove it like that for a few weeks before I could get a tune too. Dont know if youre an A4 or M6, if you dont have a stall that would make a difference too. I wouldnt drill the TB, a good dynotune will fix it.
Old Nov 10, 2010 | 03:17 PM
mamead's Avatar
I checked it over and thunderstruck was partly right-one plug wire was not fully pushed onto the plug. Fixed that and the car will idle now, although pretty rough, but as expected. Still a fair amount of backfiring tho so I want to pull the plugs and check them when I get the chance. I'm about 30 mins from Flint, where did you get yours tuned FlintWrench?
Old Nov 10, 2010 | 04:09 PM
Darkman's Avatar
I may be worng as rain, but the pushrod length looks wrong to me - like why isn't it more like 7.425?
