Quietest "stealth" cam
My thoughts are that if GM can design a cam like the LS6 that will make 400 lb/ft through stock manifolds, while passing NLEV requirements, there ought to be more torque available for trading off on the emmissions side, while still remaining legal according to my states emmissions program.
The cam is very mild and quiet. Most don't even know I have a cam until I open up a can of whoop a$Z and they ask ...
The drop in top-end rwhp is due to some pinging occurring above 6000rpm. Since the Stealth install, I had added an LS6 intake and Hi-Flow air bridge which probably leaned out the AF ratio. Anyway, I'll get Jayson to re-tune the C5 and it will probably be over 405 after that.
My vote goes to either Stealth I or II, they are both good at what they were designed for!!
Randy
