What do you think?
-Diamond Boost Pistons -8.6cc
-Lunati Pro-Mod Rods
-King or Federal Mogul Rod/Main Bearings(which one??????????)
-ARP Head Studs
Most everything will probably come from Thunder....
Then I'm thinking about boosting about 8-10psi.
Does this look good? How much power should I expect?
Any other suggestions?
Thanks
The heads/cam can come later...this other stuff is adding up to be too much. Everything I need in parts right now is about $2200 and I am already in dept before buying parts/paying labor. If I had the $$ I would do turbo cam and heads....
Pistons are $530...can you beat that?
