Head Question
Old Nov 16, 2010 | 02:39 PM
LS1BlewByU's Avatar
Default Head Question
Will OEM GM LS6 / LS2 cylinder heads, casting #243 with the D-shaped exhaust port fit my 99 LS1. I believe these heads are coming off a 05-06 Trailblazer!
Old Nov 16, 2010 | 02:59 PM
PREDATOR-Z's Avatar
Yes, you'll need gaskets and bolts.
Old Nov 16, 2010 | 03:02 PM
eray's Avatar
Thumbs up
yep sure will
Old Nov 16, 2010 | 05:07 PM
LS1BlewByU's Avatar
Awesome, what are your guys opinions good upgrade or what? I Haven't decided yet on what I want to for a cam, but im thinking PSI valve springs and titanium retainers that would accommodate up to a .625 lift. I was talking to someone and they weren't sure on if those heads would work or not beings the lS2 has a larger bore, so thats why I posted I figured yall would know.
Also, Oil pump my car has 28k on it, how hard is it do the oil pump, im doing all this work from top side, ill also be putting in a set of LS7 Lifters (the reason im tearing down is I think I have a screwed up lifter on cylinder 4 or something in the valve train let loose). Any other supporting mods or good mods to do while im in the there Cam Chain etc.....
Old Nov 16, 2010 | 05:47 PM
COSTIGAN86's Avatar
243 heads are used on newer 5.3 truck engines and 4.8 too I think
Old Nov 16, 2010 | 05:48 PM
COSTIGAN86's Avatar
You will have to lower the oil pan to access the bolt for the pickup tube to pump.
Old Nov 16, 2010 | 05:50 PM
LS1BlewByU's Avatar
Ya I have a buddy telling me to go with 5.3L heads for my car, and so your telling me these are the same heads as the newer 5.3s??
Old Nov 16, 2010 | 05:51 PM
LS1BlewByU's Avatar
Whats a good deal for these heads with nothing on them??
Old Nov 16, 2010 | 06:47 PM
COSTIGAN86's Avatar
not sure on price, but yes these are the 5.3 heads used on newer trucks. Same casting as LS6 heads but without the sodium filled valves.
