ANOTHER EPS grind in crate LS6
Old Nov 17, 2010 | 06:24 PM
kevins2000LS1's Avatar
Default ANOTHER EPS grind in crate LS6
Got inspired by the EPS baby cammed LS6 crate engine, So when my motor went south I chose the same route! Got the engine here, called Geoff and patrickG speced me a cam. Now awaiting the arrival of the new cam. My old setup was a predZ speced cam "El torro" with 853 and no pulley it run 11.4x. Hoping with the new crate engine, added pulley and the new 234/238 .602”/.604” 111LSA +4. Ill break the 10's.What you guys think?
Old Nov 17, 2010 | 06:35 PM
Hybrid86Z's Avatar
good luck man! I'm hoping for 10's NA next spring myself w/ my H/C setup on the stock bottom end LS1.
Old Nov 18, 2010 | 10:07 AM
Rise of the Phoenix's Avatar
Originally Posted by kevins2000LS1
Got inspired by the EPS baby cammed LS6 crate engine, So when my motor went south I chose the same route! Got the engine here, called Geoff and patrickG speced me a cam. Now awaiting the arrival of the new cam. My old setup was a patG speced cam "El torro" with 853 and no pulley it run 11.4x. Hoping with the new crate engine, added pulley and the new 234/238 .602”/.604” 111LSA +4. Ill break the 10's.What you guys think?
How did you like the El Torro cam? What did it pull too?
Old Nov 18, 2010 | 01:01 PM
masterz28's Avatar
thats great. cant wait to see those numbers, i have been waiting for someone with a 234/238 cam get some numbers with the eps cam, subscribed.
Old Nov 18, 2010 | 08:50 PM
I loved it! Pulled to 6300-6400. great lowend torque. really good cam specially for a stalled car.
Old Nov 18, 2010 | 09:03 PM
SOMbitch's Avatar
The "El Torro' cam was a Predator-Z cam...... Good luck and hope to see you at KDS.
Old Nov 18, 2010 | 09:09 PM
Dang my bad
Old Nov 19, 2010 | 08:51 PM
uLs1a's Avatar
I just put some LS2 243 heads and the 222/226 114 LSA cam in my Camaro, went to fire it up and tore the stater off the block
Old Nov 19, 2010 | 08:57 PM
KH504's Avatar
Dang my bad
You have the stall to do it
Old Nov 20, 2010 | 08:46 AM
hoping the SS4000 will work just perfectly
