What oil/weight r u using??
fwiw after spirited summer driving the oil pressure does drop considerably compared to "normal" driving. this tells me this already thin 30 is thinning out to **** water and the lifter clacking relatively gets louder. at what point do you see the lifters start bleeding to show drops in HP?
What is your oil pressure drop? Now granted my engine is mild by this boards standards... just an 01 LS1 with LS6 cam, heads, valves and springs so it is still more or less OEM but I don't think I have seen any lower than right under 40psi in the summer at idle, probably something like 38 since it is hard to tell the exact number from the gauge. The car has almost always been run on Pennz Platinum 5W-30 since I have had it with an AC Delco filter. I did run some 5W-30 Valvoline in a pinch this summer since I already had it, and perhaps had slightly more noise but pressure seemed similar to the Pennz Plat. That is with more or less stock idle parameters (idle speed 575RPM). I also never really have much deviation in coolant temp even in Houston temps, but the hi speed fans are kicking on bc I am always running the AC
I haven't road raced the car in the heat so I am sure that would be a real test, but if I was doing that I wouldn't be using the same oil as for DD anyway, and would probably have a dedicated oil cooler. Patman clearly states that 12-13 is what a ls1 likes according to oil analysis and noises emitted by the engine. I then searched what oils the good sponsors were recommending for GM built LS1s and looked up the viscosities on them and bingo, aligned with patman.
I have ran Castrol Syntec 5W-30 in two diffrent TA's. One I put about 50,000 miles and the other is at 70,000 miles. I have had excellent results and would highly recommend to anyone else.
ive used 5w-40 and 5w-30 on my 2002 now and i still dont have any issues or problems. i always get good oil pressure.
My LS6 has stock crank that has been polished and chamfered, Compstar rods, LS7 lifters, and an LG cam. I bought this engine off here from a guy in Florida. He told me the engine had been blueprinted and I was going to have some clearances check but ran out of money pretty much. It was a fresh build with new rods and forged pistons along with a used LG cam. I don't recall if it had new cam bearings.
When I first installed the engine I ran 5-30 and had 28lbs at hot idle. Well my sending unit started acting up and so I unplugged it until I could get it fixed. I kept an eye on level and made sure I didn't hear any sounds. Once I replaced several thousand miles later, my oil pressure indicated by the car was 7lbs hot idle. I replaced that sendin unit and the connector and only gained about 1lb. Since it was so low, I started running Castrol GTX 20-50 and now my hot idle is 17-18lbs.
The car has never made a sound even when the oil pressure was down at 7lbs. I did a proper engine break in and since then have run the car pretty hard. The engine has about 10k miles on it and has ha low oil press ever since break in but was always performed flawlessly. What would be the most likely cause of the low pressure? I'm wanting to sell the car soon and don't want to sellnit to someone knowing I have an issue with the engine.
Sorry for any spelling errors. I'm posting from my phone.
Any help would be appreciated.
slt200mph -- wouldn't 5w-40 diesel be the closest to the 0w-40. 0w-40 is what i run too btw but still burn it. pennz platnum doesnt burn a drop
