Hot Cam or Thumpr?
Old Nov 23, 2010 | 06:57 PM
GoatPilot87's Avatar
Default Hot Cam or Thumpr?
What up guys...got some questions. I have a bone stock 04 GTO auto. I'm itching for a little sound and a little more oomph. I DON'T want to run a big stall or have to swap springs every few 10 thousand miles. I really like the good rump of GM's Hot Cam and the fact it doesn't require a crazy spring. I also LOVE the rumble and fast idle of the Thumpr (p/n 275THR7) with specs as follows: 219/233 .553/.536 on a 109 LSA. I've heard the Thumpr has crap vacuum and this is my everyday driver. I just need some help choosing a small decent cam basically for sound not race. Sponsors welcome to throw your two cents in as well I you have a cam I haven't ran across that fits my description of what I need. PM me or hit me on ashnt_142004@yahoo.com and it'll pop up on the cell. Thanks guys.
Old Nov 23, 2010 | 08:25 PM
masterz28's Avatar
thumpR
Old Nov 23, 2010 | 08:55 PM
zipster's Avatar
What about the GM ASA? 228/236 .525 110 http://www.youtube.com/watch?v=uL1OhyPw9Sw
Old Nov 26, 2010 | 01:05 PM
wouldnt the ASA require a pretty decent stall? im trying to avoid that if at all possible. and im not sure the vacuum would be above 15in
Old Nov 26, 2010 | 05:21 PM
garygnu's Avatar
EPS 222/226 cam,tr224 112 lsa ,TSP 224r 112 lsa.
Old Nov 26, 2010 | 10:11 PM
99Bluz28's Avatar
Custom TSP: 224/224, 111lsa w/xe lobes, and 2.5k to 3k stall (not big stalls at all).
Old Nov 27, 2010 | 12:15 AM
NoTractionLS1's Avatar
Go with a 228/228 cam they can make good number and are easy for a DD. But in all honestly it comes down to the tune I have a TREX and it drives like stock. If you got a good tuner then he can make any cam drive perfectly fine for a DD.
Old Nov 28, 2010 | 07:37 PM
cool thanks guys. ive heard alot about the tsp cams and i like their products, loved watchin them run at the lsx shootout too. Good info on the cams everyone listed but hows vacuum oin these? have any of you guys actually measured it? I like my brakes to work, considering huntsvilles got some dumb *** drivers lol
Old Nov 28, 2010 | 07:58 PM
NVR_SPDS's Avatar
I was running TSP's 224R and didnt have a single issue with my brakes or anything else. I never measured vacuum, but didnt have any noticable issues.
Old Nov 28, 2010 | 08:04 PM
SuperSport01's Avatar
Hot Cam tuned has like stock driveabilty. The ASA cam is very driveable too. I hate Thumpr cams.. all bark.. 0 bite.
Old Nov 28, 2010 | 08:06 PM
Ok good. Yeah i've heard LOTS of mixed reviews on the Thumpr for LS and Gen 1 applications. what would be the main differences between the Hot Cam and 224, driveability, power, stall speed, etc...
Old Nov 28, 2010 | 08:24 PM
You could get away with the stock stall on the hot cam. But both the hot cam and 224 would benefit from a 2500-3000 stall. The ASA cam i mentioned would be great with a 3000-3500 stall.
Old Nov 29, 2010 | 01:06 AM
CamaroZ28_LS1's Avatar
I have a 224/228 581. 588. 114LSA cam w/ XER Lobes. It runs great with supporting mods. Good valve springs/pushrods/LS6 heads etc.
Old Nov 29, 2010 | 10:32 AM
gtotoocool1's Avatar
neither of those 2 cams if your going to keep the stock stall(or any other cam mentioned in this thread so far).if it was a lighter car and/or you were running steeper gears then that would be different.get ahold of a sponsor that can get something ground for you if your dead set on keeping the stock converter.
if it was me i would go with something along the lines of a 220/224 112-113lsa with lobes that aren't real aggressive(XE high lift comes to mind),and about a 3000 stall converter.
remember these GTOs are 3900lb cars and need to be cammed differently if being used as a DD.
just my .02
Old Nov 29, 2010 | 10:40 AM
disc0monkey's Avatar
this
Hemi2Slo's Avatar
The hot cam sounds really good and gives a decent gain, but it really benefits from a stall. You can run it without one, but you're not gonna see the full performance of it. Specially not in the goat cause of the weight.
