Buying a 2002 Z28...
Old Nov 23, 2010 | 11:49 PM
BlackHawkx24's Avatar
Default Buying a 2002 Z28...
I'm currently looking and about to buy a 2002 z28 from a dealer around me. When I went to take it out for a test drive, I noticed there was a small valve tap coming from the driver side head. The car has 49,000 miles on it and I'm just wondering if there are common problems with these valves. Or is it just from a dealership putting whatever oil (possibly not enough) or just from sitting on the lot in the cold weather. The valve tap does go away after it warms up though.
Old Nov 24, 2010 | 06:18 AM
ZYA_LTR's Avatar
Could be lifter tick or piston slap, which unfortunately are common with our cars, if it goes away after warmup, and runs strong, probably nothing to worry about.
Old Nov 24, 2010 | 06:55 AM
O2Form's Avatar
If its lifters it will tick and tap, if its piston noise it will knock and sound like a diesel. Both are normal for these engines believe it or not.
Old Nov 24, 2010 | 09:21 AM
it definitely sounds more like a lifter tick or tap and runs very strong once its warmed up. Is it something that I should not buy the car over?
Old Nov 24, 2010 | 10:18 AM
02_Z28_G's Avatar
mine did the same when i bought mine from a dealer last year. see if they know what kind of oil is in there. turns out the place where i bought mine was using 5w30 so i went to 10w30 and the noise wasn't as loud if not gone at times. i do live in texas so during summer i bump it up to w40
Old Nov 25, 2010 | 01:49 PM
drewbruce's Avatar
Default valve tap
i got a 02 Z28 and when i changed the oil in it with valvoline i noticed it started to do that problem as well. im not sure what it is yet tho but wheni find out i can tell you
