Main bolt help
Old Nov 24, 2010 | 11:06 AM
RNation0001's Avatar
Default Main bolt help
Ok bought a 5.3 block and it came with the mains but not the smaller main bolts that go in from the sides. What size n length are they and can I just get class 10.5 hardened bolts?
Old Nov 24, 2010 | 11:37 AM
Jon@Texas-Speed's Avatar
I'm not sure what size they are but you can get them at your local dealer pretty cheap I would think. Part number 12556127. If you can't get them, call us and we can get them for you.
Jon
Old Nov 24, 2010 | 12:15 PM
KCS's Avatar
KCS
Moderator
I would get the OEM bolts. They have a pretty significant influence on the housing bore for only torquing to about 18-20ft-lbs.
Old Nov 24, 2010 | 03:53 PM
joecar's Avatar
The OEM bolts also have a silicone seal molded under the bolt head.
