Timing chain install.....need some help.
Old Nov 26, 2010 | 08:25 PM
ebk06's Avatar
Default Timing chain install.....need some help.
Im installing a double roller chain and some other things. I was using the ls1hot.com write up to do my install. Well in doing so I either over looked or its not in the write up and I didnt line up the timing marks on the sprockets. Its taken me some time to even find posts telling people do to this. Well I've swapped cams already and have the new sprocket on the crank. Now can anyone tell my how I get the new timing sprockets lined up so I dont have any issues?
Old Nov 26, 2010 | 08:39 PM
krissoto's Avatar
prob have to do it old school style and pull a plug and get #1 to TDC and go from there. Im sure someone will chime in and tell ya the easy way to do it.
Old Nov 26, 2010 | 08:45 PM
ebk06's Avatar
Also the engine is on a stand so whatever way will work best is fine. This is my first go at a cam swap so this is all kind of new to me. I guess thats why I made this mistake to begin with lol.
Old Nov 27, 2010 | 12:13 AM
01ssreda4's Avatar
Im not that familiar with the double rollers, but this is an easy fix. You just want your crank sprocket to have 0 pointing to 12 oclock and your cam sprocket's 0 to be facing 6 oclock. They will be above and below each other.
Old Nov 27, 2010 | 12:27 AM
ebk06's Avatar
Thats kind of what I was thinking but I wasnt 100%. Thanks, I really didnt want to screw this up since it could have nasty results.
