Thunder Racing cam lobes?
Thanks PREDATOR-Z. In you oppinion, how do the Thunder Racing lobes stack up against the Futral/Cam Motion lobes? I know you've replied to other threads I have had, and I really appreciate it. I'm alomst 100% sure I'm going with Futral to grind my cam, but I want to make sure it's on their priority lobes, as I have read that Futral uses Cam Motion lobes, but all the Futral cams (F-13, F-14, etc.) are gound on Allan's priority lobes. I'm sure if I give him a call, I can get that taken care of. You seem to be the most informative on Cam Motion lobes, so do you know what the difference is between the Futral lobes and the normal Cam Motion lobes? Thanks for your help.
Traditional cam on the left, Cam motion on the right. You can see by shrinking the cam it makes the lobes more straight up and down. It also requires the use of longer pushrod as you can obviously tell. This way of doing things is nothing new as all aftermarket cams I know of shrink the base circle down when compared to the stock cam. Cam Motion just takes it one step further.
Thanks for your help. So if I spec my own cam and have Futral grind it, it will be on Futral's own specific lobes? I'm thinking along the lines of a 230/234 110 LSA with the lift being in the low .600's. I have heard nothing but good things about Futral/Cam Motion cams, which is why I'm going to use them. I just noticed that having Futral grind a cam is more expensive than going straight through Cam Motion, which is why I was wondering if the lobes are different. If not, then it wouldn't make any sense not to just go through Cam Motion. I've looked on the Cam Motion website, but didn't see any information about their lobes or if they have different lobes, like Comp Cams does. Any more information you have would be great. It seems to me like every swinging dick around here uses either Comp or the "latest and greatest" EPS lobes, so I can't wait to get my setup installed and post the results. Also, I don't mind if the cam is hard on the valve springs because my car is not a daily driver.
Comp does grind all of our camshafts, however we do use a wide variety of lobes on our custom cams depending on what each customer is looking for. A good bit of our shelf cams use proprietary lobes, while some use XER, LSX, XE, XFI, LSL, or a combination of different lobes. We don't use one specific lobe. Hope this cleared it up for you.
