Trickflow 215 heads and 231/237 cam
Old Nov 29, 2010 | 05:55 PM
jt76's Avatar
Default Trickflow 215 heads and 231/237 cam
I just purchased a set of trick flow cnc'd 215 heads. Some people locally have suggested that i keep my current 231/237 camshaft while others suggest i go with something different. Is there anyone currently running this setup? Any recommendations and opinions are welcome. Also, these heads are machined to 58cc so i would assume no matter what route i take i will have to fly cut (?)
Old Nov 29, 2010 | 05:59 PM
RJB01camaross's Avatar
if you add the full specs of your cam it will be easier to gauge the PTV clearence. However I would assume you will even with that cam. I will say this about the TFS heads, I have seen lots of combos with thoose heads and no matter what cam is used its always a stout combo. Thoose heads are very forgiving with cam selection. What is your goal with your car?
Old Nov 29, 2010 | 06:16 PM
jt76's Avatar
cam is as follows
Thunder Racing 231/237 112(i believe its a +2) .595/.605
as far as goals are concerned, i want to get more time at the track with this car. I am already in the process of removing a ton of weight from the car. I want it to perform well at the track and be a roll monster. As far as a HP number or ET is concerned, i really have no clue what the car will do as of yet. Old numbers were 393 wheel on a mustang dyno and 12.0's @ 119- 120 mph on bogging 1.9 60 fts.
Old Nov 29, 2010 | 06:56 PM
02BlkZ28's Avatar
I got the same setup with a 595/595 238/242 112LSA Have not gotten tuned yet but sounds like a beast www.youtube.com/watch?v=QcT-GqX39rw
Old Nov 29, 2010 | 06:58 PM
Gordon0652's Avatar
Blocks FTW - be careful!
Old Nov 29, 2010 | 10:41 PM
garygnu's Avatar
the trick flow heads and fast intake mite add 45 rwhp if tuned right.
Old Nov 30, 2010 | 03:18 PM
jt76's Avatar
so TFS heads AND a fast MIGHT add 45 hp?
Old Nov 30, 2010 | 03:30 PM
JustAFooL's Avatar
I would have thought it'd be more than 45hp.. Who knows?
Old Dec 1, 2010 | 01:03 PM
jt76's Avatar
So does anyone have any valid input?
Old Dec 1, 2010 | 03:40 PM
Always2Slow's Avatar
I think 450 on that mustang dyno you dynoed at the first time is possible if all the details aren't overlooked.
Old Dec 1, 2010 | 04:58 PM
WKMCD's Avatar
The valve angle on those heads will let you run more overlap than stock castings but you should still clay them to make sure.
FWIW: In my 346 I ran a set of well CNC'd 243 castings at 62cc's, a 230-236 112 +2 XE-R lobe cam and a ported 90/90 setup. This was in my C5. It made 460 on a DJ. I sold that setup and the new owner made 443 on a Mustang.
BTW: I really like that size cam. Much better average power than some of the donkey dick stuff people are claiming "drives like stock".
Old Dec 2, 2010 | 09:08 AM
Rise of the Phoenix's Avatar
FWIW: In my 346 I ran a set of well CNC'd 243 castings at 62cc's, a 230-238 112 +2 XE-R lobe cam and a ported 90/90 setup. This was in my C5. It made 460 on a DJ. I sold that setup and the new owner made 443 on a Mustang.
Did you have to flycut with that setup?
Old Dec 2, 2010 | 09:34 AM
WKMCD's Avatar
I probably should have. It was close and when I pulled the heads you could see where they had just barely touched the piston. Didn't do any damage. Another .010 head gasket and they wouldn't have touched. I ran Cometics .040's.
Old Dec 2, 2010 | 12:35 PM
Good to know. I should be golden then with my AFR 205's milled down to 62cc and a 230/234 110 lsa cam. I won't be running cosmetics, so I should have plenty of room.
Old Dec 2, 2010 | 03:35 PM
slt200mph's Avatar
Rather than hoping for the best .... you should check for proper piston to valve clearence...... no two motors are identical.
Old Dec 3, 2010 | 06:09 AM
got milk??'s Avatar
Hope this helps I am running a TSP TV2 its 232/234 and both intake and exhaust are just shy of .600. My TFS are shaved alittle less than 61cc. I am also running MLS gaskets When I measured with clay my PTV was right where I wanted it. No matter what anyone tells you it takes about 30 minutes to measure with clay and it will save you a ton of headache in the future. If you put everything together and then a valve kisses a piston you will be regretting not checking. After a valve nicks a piston you are on borrowed time sometimes it causes detonation and others run crappy for a while then detonate.
