lifter stuck
Old Dec 8, 2010 | 12:55 PM
SS4Luck's Avatar
Default lifter stuck
So i pulled my heads off yesterday and the exhaust lifter had rotated and is stuck in the bore so im assuming the pin is out. Problem is i drove the car like this for ~60 miles. How trashed is everything more than likely going to be?
Old Dec 8, 2010 | 01:00 PM
98z-28redcamaro's Avatar
could b bad....check your oil and see if there is any metal in it...could b clean...
Old Dec 9, 2010 | 04:55 PM
vettenuts's Avatar
Pull the cam, push the lifter out the bottom or the bore will be damaged as well.
