Patriot Gold Springs Question
Old Dec 9, 2010 | 01:42 PM
1998LS1SS's Avatar
Default Patriot Gold Springs Question
Im about to purchase a set of patriot gold springs without the bottom spring plates/base/guides (name?). Question is, can I use the stock spring plates, that is, if the stock springs come with bases/guides?
I called patriot and asked if i could purchase the 16 of the guides and they said they dont sell them. Im going to try calling again today and see if i can get a part number.
Any info would be much appreciated.
Thanks,
Tony
Old Dec 9, 2010 | 01:46 PM
01ssreda4's Avatar
Are you asking can you run a dual spring with the factory spring seat and/or valve seal? The answer is no. You must change the seats and run a valve seal thats a seperate piece. If money is tight, then look into Lunati Dual Gold complete kit. They can handle .660 lift and are $220 shipped from sponsors here on this site.
Old Dec 9, 2010 | 01:51 PM
1998LS1SS's Avatar
Actually, just found it. thanks 01ssreda4
https://www.patriot-performance.com/...&cat=51&page=2
