Is it worth swapping these cams??
Old Feb 25, 2003 | 03:44 PM
SB's Avatar
SB
Default Is it worth swapping these cams??
Considering swapping my current B1 cam with the specs of 221/221 .558 @114lsa to the C2 cam with specs of 224/224 .581 @112lsa. Will there be any significant gains of the C2 over the B1??
Car mods are in sig.
Thanks
steve <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Feb 27, 2003 | 10:59 AM
SB's Avatar
SB
Default Re: Is it worth swapping these cams??
ttt
Old Feb 27, 2003 | 11:13 AM
Intimidator's Avatar
might get about 10 hp... the 112 lsa will also give more low end power than the 114
Old Feb 28, 2003 | 12:03 AM
gator's 99TA's Avatar
i doubt you see 10 RWHP with teh cam swap alone. the 224 desribed sounds like a xe-r with the aggressive lobes. the higher lift wont help much on stock heads. i say keep what you have. maybe 5 RWHP for all that trouble, just put heads on it!
