hollow stem valves in 853 casting heads?
Old Dec 9, 2010 | 11:33 PM
99mongooSS's Avatar
Default hollow stem valves in 853 casting heads?
Can i put the valves out of a set of ls6 heads into a set of 853's? I heard that hollow stem valves are longer.
Old Dec 10, 2010 | 12:08 AM
02*C5's Avatar
You have heard right the LS6 valves only fit 243/ 799 heads they don't even fit well enough to run on a 241 head.
Old Dec 10, 2010 | 12:19 AM
TA63's Avatar
Do all 243 heads use a longer valve? If so, what length are they? I have a set with standard stem valves.
