Have a few questions
Old Dec 10, 2010 | 06:19 PM
bigcorn's Avatar
Default Have a few questions
FUDGE. pretty sure I put this in the wrong section. Can someone please move it to the right place?
I'm in the process of gathering parts for my LS2. Spun a bearing. So far I have a Moroso pan, oil filter relocation bracket, and a Melling oil pump. I'm having the heads ported and fitted with Patriot springs and the titanium locks. Also having them shaved to get 11.0 comp. The factory intake is also being port matched. I have the cam picked out so that's not an issue. Now that I've filled you in with what I have here's my questions. Where's the cheapest place to get these parts.....
LS7 lifters (Cheapest was $136 I believe)
LS2 Lifter Tray(s)
LS7 Crank (I will just machine the front and change the reluctor)(Cheapest $732)
ARP Head Studs (Cheapest I found was $247.99)
ARP Pro Series Rod Bolts (Cheapest was $95.95)
ARP Main Studs (Cheapest was $189.88)
I'm still undecided on the LS7 crank too. If I can get it cheap enough, yeah, I will do it. I really can't order a newe balancer until I've decided also.
Old Dec 10, 2010 | 06:51 PM
garygnu's Avatar
try TSP or the WS6 store,both listed to the right.>>>>>>>>>>>>>>>>>>>>
