I need help ASAP please, I have pictures inside
Old Dec 14, 2010 | 01:43 PM
vettenuts's Avatar
Originally Posted by Blue2002SS
I tried to thread a clean rod into the crank and it only goes in about 3/4 of an inch, then it starts to get difficult to turn (by hand) wich makes me think there is debris in there.
I already took a air hose and put it all the way to the bottom of that hole and blasted air,,, I had some small metal chuncks fly out in to the waiting towel.
A thread chaser is a better approach but if you don't have on then you will need to use a tap. The problem with the tap is it can remove material and since I don't know the thread class used it can change the class fit as well.
