crank sprocket removal?
Old Dec 14, 2010 | 08:54 PM
98trans-am's Avatar
Default crank sprocket removal?
I need some help removing my time sprocket and am not having any luck. its a rollmaster double roller timing set that is installed at the moment. I can see that there is a little pin installed but i am unable to remove it. after searching google I found i might need a 2 jaw puller to pull of the sprocket but i still need to remove the retaining pin. any one have any tips they can offer?
Old Dec 14, 2010 | 09:12 PM
ebk06's Avatar
That pin your talking about is probably the keyway. It doesnt need to be removed. Just use the puller and remove the sprocket.
Old Dec 15, 2010 | 12:49 AM
98trans-am's Avatar
will try it tommorow thanks for the reply
Old Dec 15, 2010 | 04:33 AM
vettenuts's Avatar
There is a special tool that you can get for removal, it is around $11 on the auction site.
Old Dec 15, 2010 | 10:42 AM
Damian's Avatar
LSX Mechanic
This.
I've got 3-4 of those tools laying around. Bought some extras just in case I broke one
