Doing cam swap .. opinions?
Old Feb 25, 2003 | 04:57 PM
Mekkadon's Avatar
Default Doing cam swap .. opinions?
Hello all. I am looking at getting a different cam put in my car. I have LS1Edit for tuning, so the sky is the limit. I'm also running stock heads and 918 springs/titanium ret. kit on a 218/222 .562 .562 cam.
I am looking at getting one of these cams (both are Lunati grinds):
230/237 .544 .543 112 LSA
222/230 .534 .544 112 LSA
The reason for low lifts is that I don't want to have to change valve springs a lot. I have an A4 with a vig 3200 stall/3.42 gears, SLP longtubes, LS6 intake, X-pipe.
I figure the long duration on these cams will let more air in (leaving the valves open longer) without having to go with a high lift cam with longer duration. I am also planning on not changing my stock heads out for a while, so optimum lift on the stock heads is, I guess, limited to around .550.
I know there is the TR 224 cam, but I was wondering...what are your opinions on such a mild lift cam with long durations???
Old Feb 25, 2003 | 05:25 PM
Cal's Avatar
Cal
Default Re: Doing cam swap .. opinions?
I've been thinking along the same lines as well. There is also a Comp Cams 224/224 .533/.533 113 that you might want to consider. In a magizine article I saw they got the RWHP over 400 with this cam.
<small>[ February 25, 2003, 05:26 PM: Message edited by: Cal ]</small>
Old Feb 26, 2003 | 06:38 AM
Mekkadon's Avatar
ttt
Old Feb 26, 2003 | 07:36 AM
Top Fuel's Avatar
what's your intended purposes for this car?
drag racing?
road racing?
is it a daily driver?
Steve
Old Feb 26, 2003 | 09:56 AM
Mekkadon's Avatar
It is a daily driver right now. I plan on keeping it pretty streetable. It sees some track time, but not a lot. I have a PTE4500 stall going in, and I plan on purchasing another daily driver, and this will become my weekend car.
Old Feb 27, 2003 | 02:58 PM
Mekkadon's Avatar
TTT <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
