can ls6 valve covers be swapped side to side?
Old Dec 16, 2010 | 03:13 AM
lavoy's Avatar
Default can ls6 valve covers be swapped side to side?
hey i got a ls6 it of course has the center bolt style valve covers, my ls1 had perimeter style so i cant reuse those and i want to swap the oil fill hole to the drivers side i wonder if there is any clearance or other reason why this cant be done? i swapped them and spun the motor by hand and did not hear or feel any problems but i want to be sure.
Old Dec 16, 2010 | 05:28 AM
S10xGN's Avatar
They'll physically interchange as you've seen. The only issue would be any accessories (hoses, clips, harnesses) that might need to be moved around.
Old Dec 16, 2010 | 11:41 PM
01ssreda4's Avatar
How in the hell are you going to fill the oil when the oil filler is under the windshield?
Old Dec 18, 2010 | 02:02 PM
lavoy's Avatar
its in a 71 datsun there is no issue with room. however my air filter off my turbo does block the oil filler when its on the passenger side.
Old Dec 19, 2010 | 01:10 AM
s/c'd cav's Avatar
ive got both pass side valve covers on my 04 gto , so you wont have any issues
