Piston rings for build with stock pistons?
Old Dec 17, 2010 | 10:44 AM
BlueBird346's Avatar
Default Piston rings for build with stock pistons?
For you pros and people with experience, need some advice. Im building an LS1 with the stock rotating assembly, what rings should I use? Im going for reliability/longevity.
Thinking about these, but wanted to hear some opinions before I buy.
(First one on the list)
http://www.speedinc.com/cont.cfm?cid=C0001055
Old Dec 17, 2010 | 04:35 PM
Isolde's Avatar
Those are plasma-moly rings, which are intended for nitrous / boost builds, which is not an application for stock pistons. GM offers new stock rings that're good for 300,000 miles in GM's own testing.
Old Dec 17, 2010 | 05:17 PM
O2Form's Avatar
Agreed, its hard to beat the rings from GM.
Old Dec 17, 2010 | 05:21 PM
Jon@Texas-Speed's Avatar
We can get some GM replacement rings or there is a set of Seal Power rings if I'm not mistaken they are $120. We can get you setup either way.
Jon
Old Dec 17, 2010 | 07:37 PM
KCS's Avatar
KCS
Moderator
Perfect Circle makes a ring set for stock LS1 bore sizes for ~$100. You can do 3.898" or 3.908" if you wanna file fit them.
Old Dec 21, 2010 | 11:21 AM
Thanks guys. Should I wait until I have the cylinders honed to determine which ones I need? If not I guess Ill get the stockers.
Old Dec 21, 2010 | 11:34 AM
KCS's Avatar
KCS
Moderator
How are you honing the block?
Usually honing will increase the bore size and may make it too big for stock pistons. In which case, you'll need oversized pistons as well as rings.
