Heads/cam finished, but have issues
I have not had a chance to check out the linkage yet. I had a death in the family last week and the memorial service is tomorrow. I will be able to get to it on wednesday. The grounds are connected to the back of the drivers side head. I am also going to check out the spark plugs and make sure all the injectors or on properly.
I checked the linkage and it was fine. I realized that it was extremley low on transmission fluid, so I filled it up. I am still having a hard time getting the key to turn, but wiggling it around it will eventually turn and the car will start.
Back to the transmission. I am still able to, with the car off and foot off the brake pedal, press the **** down on the shifter and put it in any gear. With the car off and in park with the e-brake off, the car will not roll anywhere. With the car on, foot on the brake, I can put the shifter in any gear and it will engage in that gear. I will put it in reverse and it will wanna go in reverse.
With the car running and in park, I can rev it slightly and it will rev up (oil pressure goes up to) and when it tries to idle again it will die, I believe that is due to running rich.
GM Rocker procedure was followed for stock rocker arms?
Are you throwing any codes such as 0300? If so, can you isolate a cylinder?
Have you pulled the plugs to check for non-firing plugs?
Rockers were installed correctly
The only code I have recieved was P1635
I have pulled the plugs, but I will probably pull em again this weekend and double check
