oil leak
Old Dec 22, 2010 | 04:37 AM
LSjim's Avatar
Default oil leak
hi i just put a cam in and i dropped the lifter. i thought it was in the pan so i dropped one side. I found the lifter and everything is back togeather. I fired it up and it is leaking on the bolt above the oilfilter. can i just use rtv seal and be okay? thnks
Old Dec 27, 2010 | 04:41 AM
LSjim's Avatar
i need help???
Old Dec 28, 2010 | 09:40 AM
Jon@Texas-Speed's Avatar
Is it coming out of the plate or the oil galley plug in the side of the block? You should just be able to replace the gasket or change the plug if that's the case. I wouldn't use RTV on those.
Jon
Old Jan 3, 2011 | 03:18 AM
LSjim's Avatar
But to change the gasket won't I have to Jack the engine up??
Old Jan 3, 2011 | 07:37 AM
2slow2flurry-ous's Avatar
Jon
Maybe so, but I would still listen to this guy lol. Good luck bro. Keep us updated.
Old Jan 3, 2011 | 06:40 PM
LSjim's Avatar
If I were to use the rtv would it jus leak later on ??
Old Jan 4, 2011 | 09:44 AM
We've done that method for years without a problem. The factory pan gasket should seal up fine. I wouldn't worry about replacing it.
Jon
