lq4 question
Anywho...LQ4 was pulld from a 2004? Silverado due to no oil pressure even checked with a mechanical guage.Oil pump replaced and still nothing (maybe 10psi I was told) But otherwise no knocks or strange sounds.
What could it be ?
Is it worth anything ?
The reason I'm asking is I can get it for almost nothing and if it's an easy fix I'll build it for my ride (pic below)
__________________
Oil pump worn or dirty.
Oil pump-to-engine block bolts loose.
Oil pump screen loose, plugged, or damaged
Oil pump screen O-ring seal missing or damaged
Malfunctioning oil pump pressure relief valve
Excessive bearing clearance
Cracked, porous, or restricted oil galleries
Oil gallery plugs missing or incorrectly installed.
There was a new oil pump installed and no difference
Was hoping there might have been a easy fix that was common
Unless you know that the previous owner shut it down as soon as he had a problem, the nlock is a now a rebuilder.
that is my guess.... but like stated befor... it could be alot of other things!!!
