MS3 vs HPE S cam
Old Dec 26, 2010 | 12:07 AM
mylittlez06's Avatar
Default MS3 vs HPE S cam
hey guys im gettin ready to do a cam install on my 2000 SS M6....I narrowed it down to two cams the MS3 and the HPE S cam...please do not try to steer me different then these two....im just wondering who is using or who has ran the MS3 or S cam in the past, I would like to know which one pulls harder and makes more power.....thanks
Old Dec 26, 2010 | 12:45 AM
01ssreda4's Avatar
I dunno specifics but a local guy was running the S cam and it hauled ***
Old Dec 26, 2010 | 01:06 AM
MYSTIC-1SC's Avatar
Ive been more than pleased with the TSP MS3 cam.
Old Dec 26, 2010 | 03:53 AM
SIK GTO's Avatar
I ran an S cam on my LS1 GTO, a while back. It made sick power, but with a 3600 TC the rwtq #'s were low, BUT... at 386rwhp/339rwtq it ran 7.50's (1/8 mile) N/A and 7.20's (traction limited) on spray (about a 100 shot) @ 3800lbs. Sounded awesome and was not too bad on the skreet.
Old Dec 26, 2010 | 09:22 AM
sick&twistedSS's Avatar
i have the ms3 in may car had it in there about a year now an put many of hwy miles on it an got about 27ish mpg its an awesome cam an sounds nasty, my car put down 401whp 396tq all i have is LT spintech exhaust an gears ull love it
Old Dec 26, 2010 | 09:56 AM
garygnu's Avatar
check the dyno section there are some cams smaller then a ms3 making good power.
Old Dec 26, 2010 | 10:01 AM
kidcamaro98's Avatar
I have the MS3 cam in my car. It has been in for 30k. Havent had a single issue. I drive it on 900 mile road trips every year down to myrtle beach. The car makes 412rwhp on stock 241 heads, stock intake manifold through a motive 4.10 gear. On the 100 shot, it makes 517rwhp.
The power the ms3 brings on is awesome. 3800-7k it keeps pulling and pulling.
here is a quick idol video if your interested. I also have 50+ race videos on youtube but im not going to get into that right now.
http://www.youtube.com/watch?v=iVLC2Uug2ns
Old Dec 26, 2010 | 10:17 AM
tillery's Avatar
They are almost identical. Its a drivers race of all is same on both cars. I would go with TSP cam
I ran the MS3 for 5 years. Even on a crappy tune it performed awesome. There has Been a debate about the S cam being a copy of the other. Either way. Properly installed and tuned you wont know the difference between the two.
Old Dec 26, 2010 | 01:31 PM
STAGEUP's Avatar
I have an MS3 cam with a 113 LSA in my 4,000 lb CTS-V, and I love it! Its my daily driver and has great street manners. Once my LS6 hits 3800 rpms, you better hold on! Haaa. Its pulls hard all the way to 7k.
Old Dec 26, 2010 | 02:28 PM
any of you guys with the MS3 have any 1/4 mile times?
Old Dec 27, 2010 | 07:07 PM
McLuvin's Avatar
Mine ran a 12.56 @ 106 last year. No spray.
Old Dec 27, 2010 | 08:11 PM
12.8 @ 116 on street tires....no traction until mid 3rd.
Old Dec 28, 2010 | 01:36 AM
my buddy has an LS6 intake of a CTS-V....will that work on my car?
Old Dec 28, 2010 | 08:30 AM
yes....
Old Dec 28, 2010 | 09:56 AM
thanks
Old Dec 28, 2010 | 10:54 PM
Philip@HPE's Avatar
These cams are very close and will offer very similar performance/drivability...while I am biased towards our own cam, you can't go wrong with either.
That debate works both ways but as I have already stated, both are great cams.
Old Dec 29, 2010 | 05:42 AM
PREDATOR-Z's Avatar
Actualy both of them are copied after another grind
Old Dec 29, 2010 | 10:23 PM
yeah im prob gonna go with the MS3...they seem to be alot cheaper if you buy one of there cam packages....I can get the MS3 with whatever LSA I would like, PRC valve springs, pushrods and lifters for $689
Old Dec 30, 2010 | 12:34 AM
RyanJM's Avatar
I have a MS3 113LSA with a 3200 stall and 3.73's and it's fun to drive and sounds great. Still working the tune and have to dyno it. No track times till I can get a new rear and Dr's. Even with the small 3200 stall the 3.73's get it into power quick but the tires break loose easy. But ya after 3500 rpm the cam just pulls all the way to the 6500-6600rpm shift point I have it set at. With a M6 you may want to get some 4.10's since the cam is lazy under 3000.
Old Dec 30, 2010 | 08:17 AM
when your WOT, when are you going to be under 3000rpms anyways, other then coming from a dig?
I had the stock 3.42's in my car with the ms3 for about 20k, then I figured I would have 4.10's installed. I am going back to 3.42's. The 4.10's absolutely kill this cam if its not strictly a drag strip car IMO. 3.73's with the M6 would be a better choice. Not to mention when im spraying, I need to shift every 3 seconds.
