compression question
Old Dec 27, 2010 | 04:46 PM
Chevyboy82188's Avatar
Default compression question
I have a 383 ls1 with a 11.1 comp ratio im going to put on 317 heads to drop it to 10.1 so what head gaskets should i use to get me to ~9.5cr?
Old Dec 27, 2010 | 05:03 PM
PREDATOR-Z's Avatar
Is this a boosted application?
What size reliefs in your pistons?
Old Dec 27, 2010 | 05:19 PM
yes going to be running a borg warner s472 turbo. My pistions have a -1.6cc
Old Dec 27, 2010 | 05:32 PM
PREDATOR-Z's Avatar
You should have got deeper piston reliefs. Even with .060 gaskets, you'ld still be at ~10.4:1
Old Dec 27, 2010 | 05:42 PM
how is that? im told that the 317 heads will drop my comp 1 point? that would take me to 10.1....
Old Dec 27, 2010 | 05:52 PM
speedtigger's Avatar
Old School Heavy
Nothing more reassuring then doing your own math:
http://www.rbracing-rsr.com/compstaticcalc.html
Old Dec 27, 2010 | 06:08 PM
not 100% sure on the numbers quite yet but with my setup and .060 headgasket i should get a ~9.6 comp ratio?
Old Dec 27, 2010 | 06:33 PM
Old School Heavy
What are the CCs of your current heads?
Old Dec 27, 2010 | 07:36 PM
317 heads will be 72cc
Old Dec 27, 2010 | 08:09 PM
I think my motor is 11.4:1 so with those heads and a .086 gasket gets me to 9.8:1.........
Old Dec 28, 2010 | 12:12 PM
PREDATOR-Z's Avatar
You can't just run any gasket thickness you want. .060 would be max. That is why I mentionned it.
My advice is do some more research on your motor and try to understand its limits.
Old Jan 15, 2011 | 11:03 PM
Dont worry im not askin for your advice went and talked to a good engine builder/machine shop he ordered me .70 gaskets to get 10:1 he said im fine..........
Old Jan 16, 2011 | 08:07 AM
35th camaro's Avatar
Sure sounded like you were asking for advice
Old Jan 16, 2011 | 11:27 AM
Old School Heavy
So there! LMAO
Old Jan 17, 2011 | 05:40 PM
PREDATOR-Z's Avatar
Best of luck on your build, just don't drive with the same attitude, you'll hurt somebody
Old Jan 17, 2011 | 06:42 PM
cacmanjr's Avatar
Guys, I don't mean to hijack the thread but I have a question related to calculating compression. What is the stock deck height on an ls1. I have read that the piston sticks out of the hole. Is that true? By how much?
Old Jan 17, 2011 | 06:56 PM
TA63's Avatar
You want a tight quench to reduce the possibility of detonation, esp with forced induction. Might want to rethink this a little. Maybe see if your shop can open up the combustion chambers on the 317's 3-4cc's each?
Old Jan 17, 2011 | 07:34 PM
PSnewbie's Avatar
Wouldn't thicker head gaskets be more prone to failure on an FI motor?
Old Jan 18, 2011 | 02:53 PM
PREDATOR-Z's Avatar
That too, but I've seen Nelson motors holding fine with .060 gaskets if done right. Mainly as mentionned you want to limit detonnation, to do so, the right quench is preferable (to benefit from maximum timing advance)
Old Feb 4, 2011 | 04:15 PM
Whiteaw57's Avatar
what exactly is quench? Is that the relation of the piston face to the head surface?
