manley install height
Old Dec 28, 2010 | 02:22 PM
95maroz28's Avatar
Default manley install height
i got a set of used manleys for a baby cam im about to install but seen they had two install heights, 1.75" and 1.8". would anyone know the right height for a set of manley duals? thanks
Old Dec 28, 2010 | 02:46 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Which Manley springs? Is it their kit? If not, what retainer are you running? What cam specs are going with it?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Dec 29, 2010 | 02:37 AM
95maroz28's Avatar
im assuming its a kit was pulled off ls1 heads. It looks to be a dual spring and steel retainers. cam is just around 218/228 554 570. thanks bud i hope to get started this weekend when i rent a damper puller
Old Dec 29, 2010 | 07:37 AM
vettenuts's Avatar
Manley is liking providing two seat values at two installation heights. The actual installed height is determined by the seat value required by the cam. I would shoot for 135# on the seat and figure out what installed height is required. Do you have a shim kit to adjust the seat value (installed height)?
Old Dec 30, 2010 | 05:42 AM
95maroz28's Avatar
no i dont have a shim kit, where can i get one? im gonna run a 10-12 lbs also thus the reason for the spring change but found this cam for pretty cheap.. thanks for your help
Old Dec 30, 2010 | 07:15 AM
vettenuts's Avatar
Not sure what your seat value should be for a boosted application. I would contact Manley to get a value but you probably need more seat force then 135#. The shims are available from Comp. Manley may also have them.
Old Dec 30, 2010 | 04:17 PM
TurboBuick6's Avatar
10-12lbs I would shoot for around 140-150 closed and 400 open.
